My understanding of hamming code (adding this as it might help someone in future):
Description: Hamming code is basically an extended parity check code. Message is divided into blocks, and multiple parity bits are added in each block of message (by the transmitter) in a way that these bits indicate the position of the error bit in that block.
Code-word: Each block (message + parity bits) forms a code word. The list of valid code words is known both to the transmitter and the receiver. Whenever a block is found not to match the list of code words, it is considered as error, and a correction is applied.
Hamming distance: It is the number of bits that differ between a pair of valid codewords. The minimal distance among the all possible pairs of valid codes is called the minimal hamming distance.
Questions:
Currently am using parity method to generate hamming codes. As an an example, I will do the following to generate a (7,4) hamming code
- Define positions 1-7 for the 7 bits of block.
- Designate position {1,2,4} , which are powers of 2, for parity bits.
- Designate other positions {3,5,6,7} for data bits
- Compute parity bits which will be a function of data bits present in the subset of the above positions and form the code.
Will the above algorithm guarantee the code-words generated will have a minimal hamming distance of 3? If not which algorithm I should use to solve the problem of generating hamming codes with the given (or specified) minimal distance?
Note: Since it was a laborious task to find the minimal distance of the generated 7 bit code-words, I am posting this question here to know the general procedure for generating hamming codes with the given (or specified) minimal distance
