Using Vivado 2017.4, I am trying to use a clock signal generated by the Clocking Wizard IP. I copied the instantiation and component code block from the Instantiation template, but I am getting some errors related to signal declaration. I have assigned the "count" signal under my architecture header, yet I keep getting an error saying " is not declared".
In addition to "count" I am also getting the same error with my "clk_wiz_0" variable even though I created the component. I also have some syntax warnings that could be contributing to the errors.
I have tried moving the library declarations to after the entity block but that didn't help. I don't think I'm missing any libraries either.
I am new to VHDL so maybe there are some type or syntax issues I am missing? --> signifies a "error <> not declared" error and * indicates syntax warnings. Thanks in advance!
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity mmcm is
Port( clk_fpga : in STD_LOGIC;
reset : in STD_LOGIC;
lock_led : out STD_LOGIC;
counter_led : out STD_LOGIC);
end mmcm;
architecture Behavioral of mmcm is
signal clk_10M : std_logic;
signal count : std_logic_vector(3 downto 0);
component clk_wiz_0
port
(-- Clock in ports
-- Clock out ports
clk_10M : out std_logic;
-- Status and control signals
reset : in std_logic;
locked : out std_logic;
clk_in1 : in std_logic
end component;
*mmcm_inst : clk_wiz_0*
port map (
-- Clock out ports
clk_10M => clk_10M,
reset => reset,
locked => locked,
-- Clock in ports
clk_in1 => clk_in1
ATTRIBUTE SYN_BLACK_BOX : BOOLEAN;
-->ATTRIBUTE SYN_BLACK_BOX OF clk_wiz_0 : COMPONENT IS TRUE;
ATTRIBUTE BLACK_BOX_PAD_PIN : STRING;
-->ATTRIBUTE BLACK_BOX_PAD_PIN OF clk_wiz_0 : COMPONENT IS "clk_in1, clk_10M,
reset, locked";
*process (clk_10M, reset) --count from 0 to 9 at 10MHz*
begin
if reset = '1' then
-->count <= "0000";
*elseif clk_10M'event and clk_10M = '1' then*
if count = 9 then
-->count <= "0000";
*else*
-->count <= count + 1;
*end if;*
end if;
end process;
counter_led <= '1' when count = 9 else '0';
end Behavioral;
