Here is an example how to define the 2*N array of enum types of {S0,S1,S2,S3}:
typedef enum logic [N-1:0][1:0]{S0,S1,S2,S3} state_t; (*)
So, each element of the above 2*N array could be either S0 or S1 or S2 or S3.
Let's say the {S0,S1,S2,S3} are defined as a separate enum type:
typedef enum {S0,S1,S2,S3} st_t;
So how now could I rewrite the first statement (*)?
Could it be re-written as the following:
typedef enum st_t [N-1:0][1:0] state_t;
Thank you!
To the best of my knowledge typedef enum logic [N-1:0][1:0]{S0,S1,S2,S3} state_t; should not compile, and I was not able to get it to compile on any simulator on EDAplayground. Enums need a simple vector datatype. logic [N-1:0][1:0] is a double packed array and thereby isn't simple.
If you do not specify the data type of an enum, it is assumed to be an int.
typedef enum st_t [N-1:0][1:0] state_t; has a similar problem as your original statement, but now you define an enum as an double packed enums. Plus you never define the enum values.
What will work:
typedef enum logic [1:0] {S0,S1,S2,S3} st_t;
typedef st_t [N-1:0] state_t;
Or as an unpacked array:
typedef st_t state_t [N];
Read more about user-defined types (typedef) and enumerations (enum) in IEEE Std 1800-2012 § 6.18 User-defined types and § 6.19 Enumerations
Try differnet combinations on your SystemVerilog simulator or a one of the many simulators on EDA Playground (Use one of the commercial simulators, the free ones have limit if any SV featurs)
| improve this answer | |
  • \$\begingroup\$ Cannot I define the {S0,S1,S2,S3} as a separate type? Something like that: typedef enum {S0,S1,S2,S3} ss_t; typedef enum logic [1:0][ss_t] st_t; typedef st_t state_t [N]; \$\endgroup\$ – John Feb 20 '18 at 20:04
  • \$\begingroup\$ You cannot define an enum with another enum. An enum’s datatype must be a simple vector type (ex int, logic [7:0], byte, bit [23:0], etc). If a datatype is not specified then int is assumed. typedef cannot be treated as macros. \$\endgroup\$ – Greg Feb 20 '18 at 20:34
  • \$\begingroup\$ Could the above be re-written as following (using `define for substitution): (tick)define ss_t {S0,S1,S2,S3}; typedef enum logic [1:0] (tick)ss_t st_t; typedef st_t state_t [N]; As far as I understand, this is a 3-D array, correct? \$\endgroup\$ – John Feb 21 '18 at 0:15
  • \$\begingroup\$ No, it is a 2-D array. {S0,S1,S2,S3} is the legal content of the enum, it does not determine the bit-width. The logic [1:0] specifies the bit-width, bit-state type (eg: bit vs logic), and if it signed/unsigned. enum logic [1:0] {S0,S1,S2,S3} is an 2-bit unsigned enum where S0=2'b00, S1=2'b01, S2=2'b10, S3=2'b11. In contrast enum {S0,S1,S2,S3} is a 32-bit signed enum where S0=32'd0, S1=32'd1, S2=32'd2, S3=32'd3 (there is zero padding) \$\endgroup\$ – Greg Feb 21 '18 at 1:02
  • \$\begingroup\$ Greg, thanks a lot for your explanations. Anyway, could the above code be re-written as following: (using `define for substitution): (tick)define ss_t {S0,S1,S2,S3}; typedef enum logic [1:0] (tick)ss_t st_t; typedef st_t state_t [N]; ? \$\endgroup\$ – John Feb 21 '18 at 2:00
