I have STM3220G-EVAL board (STM32F207IG MCU). I'd like to measure (approximately) its actual Ethernet throughput (board <-> Windows PC).
I have CubeMX sources. There are several examples (TCP, UDP, TFTP, web server). Which protocol, parameters and algorithm should I use? For example, passing file splitted into datagrams of certain size and so on.
  • \$\begingroup\$ You mean you wanna measure inside your microcontroller code ? \$\endgroup\$
    – Mitu Raj
    Feb 20, 2018 at 18:56
    \$\begingroup\$ No, I can create or use existing utility for Windows. \$\endgroup\$
    – ilya
    Feb 21, 2018 at 6:26
You can use "wireshark" software in your windows PC, to monitor incoming and outgoing Ethernet packets. It can also calculate the throughput of the data transfer. For more details:
https://www.google.co.in/amp/blog.davidvassallo.me/2010/03/22/measuring-bandwidth-using-wireshark/amp/
