I am having difficulty calculating the gain and input resistance of the circuit below.
Neglecting ro, capacitance, and considering Ibias as ideal (infinite resistance), would this mean that the current from M1 is 0 (gm1Vgs)?
And further, indicating that the output voltage is 0?
Regarding the input resistance, I am not sure how to treat small-signal vo. I found a similar case regarding a common source with source degeneration, where the author (Razavi) was calculating the output impedance, and he shorted the small-signal input. I am not sure if this applies to the circuit below. Also, similar to the case above, since gm1Vx = 0, would this mean the input resistance in 0?
M1 is causing me lots of problems. If the input resistance is 0 this would imply that the noise figure would be 0. If you consider a source with resistance Rs, the alpha value (Rin/(Rin+Rs)) is 0, thus the noise from Rs is zero. Meaning the total noise figure would be each noise contribution divided by 0.
