I am hunting around for a cable with twisted-shielded pair conductors with the correct differential characteristic impedance for RS-485 (120 ohm)
Most of the cable spec sheets for cables with twisted shielded pair just say "Characteristic Impedance = ... " (here is an example: http://www.alphawire.com/Home/Products/Cable/Alpha-Essentials/Communication-and-Control-Cable/6365?device=pdf)
Is this referring to the differential impedance of the two conductors or the impedance of a single conductor?
transmission line
impedance. A twisted pair is a balanced line. Google transmission line for more information. It takes into account that both wires are the transmission line. 120 ohms is pretty common for twisted pairs. I'm surprised that your link specs 75 ohms. \$\endgroup\$ – lakeweb Feb 20 '18 at 23:42
