everyone. I design a Finite State Machine and try to implement it using VHDL, but the result confuses me. I take too much time on this but I still cannot solve this. Could you give me some advice ?
The logic of State Machine as below:
if flag = '0', then cnt <= cnt + '1' ; if cnt equals 12, the process will be reset. I write the VHDL code for this, as below:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.all ;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity getCANID is
generic ( IDNUM : natural := 11) ;
port ( clk_sample, rst : in std_logic ;
start : in std_logic ;
flag : in std_logic ;
cnt_dis : out std_logic_vector(3 downto 0) );
end getCANID;
architecture Behavioral of getCANID is
type State is (s0, s1, s2, s3) ;
signal present_state, next_state : State ;
signal cnt : std_logic_vector(3 downto 0) ;
begin
state_clocked : process(clk_sample, rst)
begin
if rst = '1' then
present_state <= s0 ;
elsif clk_sample'event and clk_sample = '1' then
present_state <= next_state ;
end if ;
end process ;
state_comb : process(present_state, start, flag)
begin
case present_state is
when s0 => cnt <= (others=>'0') ;
if start = '1' then
next_state <= s1 ;
end if ;
when s1 => cnt <= (others=>'0') ;
if flag = '0' then
cnt <= cnt + '1';
next_state <= s2 ;
else
next_state <= s3 ;
end if ;
when s2 =>
if cnt = (IDNUM + 1) then
next_state <= s0 ;
else
if flag = '0' then
cnt <= cnt + '1';
next_state <= s2 ;
else
next_state <= s3 ;
end if ;
end if ;
when s3 =>
next_state <= s0 ;
else
if flag = '0' then
cnt <= cnt + '1';
next_state <= s2 ;
else
next_state <= s3 ;
end if ;
end if ;
end case ;
end process ;
cnt_dis <= cnt ;
end Behavioral;
I write a testbench to simulate this simple proj. but the result is what I want.
I think the cnt should keep increasing when flag equals '0' at every rising edge of the clock. The result seems confusing. Could you help me?
The development tool is: Xilinx ISE 14.7
S3
.. why is theif flag = '1'
loop there? \$\endgroup\$ – jsotola Feb 21 '18 at 17:05
