I'm designing a control circuit to operate a watering system. I've got a main inlet valve, four outlet valves, and soil moisture sensors in the mix, driven from a 25.4 V CT transformer. I was wondering if someone could review the schematic diagram. I have to make sure I didn't do anything outstandingly stupid, considering this is my first foray into controlling solenoids via MOSFETs / relays. Some explanation of the schematic is in order:
Upper left:
PIN1 is +12 VAC from the transformer
PIN2 is 0 VAC
PIN3 is -12 VAC
Lower left:
PIN1/PIN2 go to the main inlet valve, a 24 V solenoid valve.
The PIN1/PIN2 combinations across the top go to the outlet valves, all of which are 12 VDC solenoid valves.
The PIN1/PIN2 conbinations across the bottom go to the soil dampness sensors (simple soil moisture sensors made from plaster of paris and galvanized nails).
The data pins go to analog pins on the Arduino. Signal pins go to digital pins on the Arduino. The Arduino is powered from the V+/GND pins via its Vin pin.
    \$\begingroup\$ Quick warning: Please fix the orientation and location of the labels on your components so that they aren't right on top of each other. You can do this with the smash button. \$\endgroup\$ Jul 14, 2012 at 19:48
  • 7
    \$\begingroup\$ I'm attempting to modify the schematic to make it look better. Olin, you might want to try constructive criticism instead of being an ass. I'm pretty much a beginner with Eagle and still learning how to use it's full potential. \$\endgroup\$
    – John
    Jul 14, 2012 at 20:08
    \$\begingroup\$ Curious where this discussion will go! lol \$\endgroup\$ Jul 14, 2012 at 20:22
  • 4
    \$\begingroup\$ This has nothing to do with your proficiency with Eagle or electronics. It is about the discipline-independent universal cause and effect that if you present something sloppily you will make a bad impression. The conversation then becomes about the presentation instead of its content. This is the same for electronics, pie baking, or basket weaving. You should have been able to look at your schematic and see it was a mess. Note that I'm not talking about the circuit that shematic represents, only the schematic itself. It's a lot like someone asking a question using all texting shorthand. \$\endgroup\$ Jul 14, 2012 at 21:22
  • 4
    \$\begingroup\$ John, I've been here long enough to know that this is a very sensitive issue with Olin. But I also think this isn't good. There are just a few components and it's already completely illegible. Your excuse is that you're a beginner with Eagle, but that's exactly the time when you should learn to pay attention to this. If you don't do it now, when will you? And don't take Olin's language personally, that's the way he reacts to things like this. \$\endgroup\$
    – stevenvh
    Jul 14, 2012 at 22:25
  1. Schematic needs part numbers or a BOM attached. eg what type of cap?
  2. Card interface needs protection for ESD sensitive devices on interface pins such as MOSFET gates. or a warning label.
  3. Relay contacts may need ferrite filters to reduce ingress of signals from sprinkler wires (antennae) and internal electronics. CM ferrite choke recommended.
  4. Also contacts can create peak AC transients to be radiated from interface cables to nearby electronics connected to this card.
  5. Since these are not zero crossing switched solenoids, it is hard to say if there will be any EMC surge ingress issues at a system level but filtering or shielding may be necessary and use twisted pair wires. Otherwise, contacts may be heard on AM radio which you can use off channel as a quick test. concur with other suggestions.
  6. An LED indicator & resistor on board and each driver may be useful. 3mA or so should be adequate with any low cost AlGaAs indicator rated for 20mA.
  7. Schematic needs legible notes for interfacing requirements, test points
  8. Galavanized nails are highly unreliable for reliable plant moisture sensors but for crude watering, it may be acceptable. Capacitance mode is more reliable than resistive mode for linear thresholds due to drift in soil shrinkage around sensor, galvanic soil offset, AC hum, RF noise etc.. I hope you have done some research.
It is hard to read, but possible.
  • \$\begingroup\$ whops you handy engineer \$\endgroup\$ Jul 18, 2013 at 3:59
While the schematic is a little messy, there was actually nothing unreadable about it. I can appreciate that using a new software package can be a little overwhelming, and sometimes details like that can be overlooked.
The MOSFETs look OK. They're N channel for the low side. You've remembered the flyback diodes on the solenoids. Relay looks OK.
I'm not sure if your soil dampness sensors will work. It looks like you're using the soil as the top half of a potential divider. Where is the bottom half? Is it on the Arduino?
