I am looking for a microcontroller similar to the ESP8266, which has the following features:
1/ 36 dedicated gpio
2/ I2S for driving audio
3/ I2C for driving screens
4/ SPI
5/ WiFi Station and AP modes
6/ Any language will do
I want at least 36 pins gpio, all of which would be used and then additional pins for the other needs such is I2C, I2S SPI.
Spec wise it could be a bit more powerful than the esp8266, and need not be Arduino compatible, I just want it to be good value. Advice from enthusiasts with more experience than me would be appreciated.
Many thanks
  • \$\begingroup\$ Product recommendations are off topic for this site, but since the answer is so glaringly obvious I can't help myself. ESP32. \$\endgroup\$
    – Dampmaskin
    Feb 22, 2018 at 15:45
I usually downvote shopping questions, but this one sounds general enough that it could benefit others.
It sounds like you want the ESP8266's bigger brother, the ESP32. It has more I/O, is faster (and comes in dual-core variants) and more/better peripherals than its little brother.
However, if all you need is extra digital I/O, take a look at the many port expanders available. Just go to Digi-Key, Mouser, TME or your favourite sourcing sites and start using their searches. Many port expanders operate over I2C, can support multiple expanders on a single bus, and come with interrupt capability (so the host MCU doesn't have to continuously poll the slow I2C bus for status changes).
