this is my first electronics project that i am doing so my understanding is pretty basic. I am using an ESP8266 connected to a L293D motor driver to power a bipolar stepper motor. The issue I am having is the pin connections.
This is the microcontroller that i am using. It has 9 GPIO pins at 3.3V.
This is the driver I am using.
My first question is whether I can use the 3V out of the micro controller to power the EN pins? On the data sheet, on Recommended Operating Conditions, the High-level input voltage is a minimum of 2.3V so I guess this would be ok?
Secondly, I am trying to drive a 12V bipolar stepper motor so I am unsure whether I would need to use a second motor driver due to the lack of available pins on the driver.
L293D has two channels and it can control two motors. One in each channel. The maximum current which can be drawn from a channel = 600 mA with peak output of 1.2 A. The current rating of the motor supply should be enough to drive both motors. The Vcc has to be at least 4.5 V says L293D data sheet. So powering it by 3.3 V would be a gamble as noise margins would be small. If you power it by at least 4.5 V, then you can make sure that anything over 2.5 V is enough to drive a logic high to enable pins.
| improve this answer | |
This IC is for one stepper motor, so yes, you will need a second IC for a second motor. You can reuse some pins from this one's control system, just need dedicated EN pins. Don't forget the heatsink and the additional 5V supply for the chip.
