I am am reading ADC via DMA on the STM32 Nucleo F334R8. However, after I start the DMA using the code below, the main while loop fails to execute
HAL_ADC_Start_DMA(&hadc1, (uint32_t *)&ADC_Raw, 4);
I understand that the DMA interrupts may be occurring so often that it may not allow other interrupts to occur, so I have changed the priority for the DMA to be low as possible:
HAL_NVIC_SetPriority(DMA1_Channel1_IRQn, 0, 15);
HAL_NVIC_EnableIRQ(DMA1_Channel1_IRQn);
I know that other interrupts are being handled as the following modules are operational:
- UART, send and receive message through a COM port
- TIMER, toggle an LED every 500ms
- PUSH BUTTON, turn on a LED based on a push button press.
I don't understand why the main while loop will not execute if the ADC DMA is enabled. If I comment out the code below, the the main while loop will execute
Here is the ADC configuration:
void MX_ADC1_Init(void)
ADC_MultiModeTypeDef multimode;
ADC_ChannelConfTypeDef sConfig;
hadc1.Instance = ADC1;
hadc1.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV2;
hadc1.Init.Resolution = ADC_RESOLUTION_12B;
hadc1.Init.ScanConvMode = ENABLE;
hadc1.Init.ContinuousConvMode = ENABLE;
hadc1.Init.DiscontinuousConvMode = DISABLE;
hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
hadc1.Init.NbrOfConversion = 4;
hadc1.Init.DMAContinuousRequests = ENABLE;
hadc1.Init.EOCSelection = ADC_EOC_SEQ_CONV;
hadc1.Init.LowPowerAutoWait = DISABLE;
hadc1.Init.Overrun = ADC_OVR_DATA_OVERWRITTEN;
if(HAL_ADC_Init(&hadc1) != HAL_OK)
_Error_Handler(__FILE__, __LINE__);
if(HAL_ADCEx_Calibration_Start(&hadc1, ADC_SINGLE_ENDED) != HAL_OK)
/**Configure the ADC multi-mode
multimode.Mode = ADC_MODE_INDEPENDENT;
if (HAL_ADCEx_MultiModeConfigChannel(&hadc1, &multimode) != HAL_OK)
/**Configure Regular Channel
sConfig.Channel = ADC_CHANNEL_1;
sConfig.Rank = 1;
sConfig.SingleDiff = ADC_SINGLE_ENDED;
sConfig.SamplingTime = ADC_SAMPLETIME_19CYCLES_5;
sConfig.OffsetNumber = ADC_OFFSET_NONE;
sConfig.Offset = 0;
if(HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
sConfig.Channel = ADC_CHANNEL_2;
sConfig.Rank = 2;
sConfig.Offset = 0;
sConfig.Channel = ADC_CHANNEL_6;
sConfig.Rank = 3;
sConfig.Offset = 0;
sConfig.Channel = ADC_CHANNEL_7;
sConfig.Rank = 4;
sConfig.Offset = 0;
void HAL_ADC_MspInit(ADC_HandleTypeDef* adcHandle)
GPIO_InitTypeDef GPIO_InitStruct;
if(adcHandle->Instance == ADC1)
/* USER CODE BEGIN ADC1_MspInit 0 */
/* USER CODE END ADC1_MspInit 0 */
/* ADC1 clock enable */
__HAL_RCC_ADC12_CLK_ENABLE()
/**ADC1 GPIO Configuration
PC0 ------> ADC1_IN6
PC1 ------> ADC1_IN7
PA0 ------> ADC1_IN1
PA1 ------> ADC1_IN2
GPIO_InitStruct.Pin = GPIO_PIN_0 | GPIO_PIN_1;
GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
GPIO_InitStruct.Pull = GPIO_NOPULL;
HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
/* ADC1 DMA Init */
/* ADC1 Init */
hdma_adc1.Instance = DMA1_Channel1;
hdma_adc1.Init.Direction = DMA_PERIPH_TO_MEMORY;
hdma_adc1.Init.PeriphInc = DMA_PINC_DISABLE;
hdma_adc1.Init.MemInc = DMA_MINC_ENABLE;
hdma_adc1.Init.PeriphDataAlignment = DMA_PDATAALIGN_WORD;
hdma_adc1.Init.MemDataAlignment = DMA_MDATAALIGN_WORD;
hdma_adc1.Init.Mode = DMA_CIRCULAR;
hdma_adc1.Init.Priority = DMA_PRIORITY_LOW;
if(HAL_DMA_Init(&hdma_adc1) != HAL_OK)
__HAL_LINKDMA(adcHandle, DMA_Handle, hdma_adc1);
/* ADC1 interrupt Init */
HAL_NVIC_SetPriority(ADC1_2_IRQn, 0, 14);
HAL_NVIC_EnableIRQ(ADC1_2_IRQn);
/* USER CODE BEGIN ADC1_MspInit 1 */
/* USER CODE END ADC1_MspInit 1 */
Here is the DMA configuration:
void MX_DMA_Init(void)
/* DMA controller clock enable */
__HAL_RCC_DMA1_CLK_ENABLE();
/* DMA interrupt init */
/* DMA1_Channel1_IRQn interrupt configuration */
Here is the main:
int main(void)
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
/* MCU Configuration----------------------------------------------------------*/
CPU_CACHE_Enable();
/* Reset of all peripherals, Initializes the Flash interface and the Systick. */
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
/* Configure the system clock */
SystemClock_Config();
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
/* Initialize all configured peripherals */
MX_GPIO_Init();
MX_DMA_Init();
MX_ADC1_Init();
MX_I2C1_Init();
MX_SPI1_Init();
MX_TIM1_Init();
MX_TIM3_Init();
MX_TIM6_Init();
MX_USART2_UART_Init();
my_printf("Version 1.0\n");
InitializeControllerCommand();
while (1)
if(start_pwm == true)
fade_LED();
if(readInput == 1)
readInputPin();
