7
These mate with one another (in the obvious male-to-female chain). They seem to be male-to-female banana plug adapters. Maybe I am being naive, but these seem useless. What are these useful for in practice?
EDIT: They do not come apart, i.e. they are not banana plugs waiting to be soldered to wire.
The only thing I can think of is that they're intended to be connector savers.
They look like they are adapters for shrouded banana plugs. As far as I can tell from your photograph, the red plugs have bodies which narrow after a ridge and the black ones have a uniformly narrower diameter. The narrow bodies fit inside the shrouds of the shrouded plugs.
Shrouded banana plugs
  • \$\begingroup\$ Huh? To me they look exactly the same. \$\endgroup\$ – stevenvh Jul 16 '12 at 8:18
  • \$\begingroup\$ @stevenvh - I meant the red plugs/adapters in the OP's photograph have bodies which narrow after a ridge. The black ones don't have this ridge but on closer inspection they seem to have a uniformly narrower diameter anyway. \$\endgroup\$ – MikeJ-UK Jul 16 '12 at 8:44
  • \$\begingroup\$ I will check them when I get home--I have both the larger and smaller OD shrouded banana plug handy and I can tell you which they are. \$\endgroup\$ – Alex Hirzel Jul 16 '12 at 17:03
