I am a little rusty with flip-flops.
Consider this diagram:
This is a 4 channel stereo digital switcher. I am trying to understand the flip flop and the OR parts.
Because this is a 4 channel switcher, my feeling says that the flip-flops and the OR gates will be providing 4 different outputs and I am trying to understand how it works.
Lets talk about FF1 and FF2.
When the circuit is first powered, C15 is an "short circuit" and will let 5 volts reach R17, making FF1 clock be 1 for a brief period of time and then charge and "cut" the current to R17, making it 0 volts. So, we see clock going from 1 to 0, during startup.
Because this D-Flip-flop CD4013 will not do anything on 1 to 0 clock transition, I think FF1 will be with the following states after startup: (Q = 1), (Q' = 0), (D = 1).
Because of the wiring between FF1 and FF2, after startup FF2 clock will be 1, (Q = 0), (Q' = 1) and (D = 1).
At this point the OR ports will be with these states (from top down):
N1 (0, 0).... output 0
N2 (1, 0).... output 1
N3 (0, 1).... output 1
N4 (1, 1).... output 1
Then I press S1. We have a transition from 0 to 1 on FF1 clock.
FF1 changes to the following states: (Q = 1), (Q' = 0 = D)
Nothing happens on FF2.
The OR ports are now
N1 (1, 0).... output 1
N2 (0, 0).... output 0
N3 (1, 1).... output 1
N4 (1, 0).... output 1
I press S1 again. We have a transition from 0 to 1 on FF1 clock.
FF1 changes to the following states: (Q = 0), (Q' = 1 = D)
Now the clock of FF2 changes from 0 to 1
So, FF2 changes to: (Q = 1), (Q' = 0 = D)
N1 (0, 1).... output 1
N2 (1, 1).... output 1
N3 (0, 0).... output 0
N4 (0, 1).... output 1
N1 (1, 1).... output 1
N2 (0, 1).... output 1
N3 (1, 0).... output 1
N4 (0, 0).... output 0
So, in sequence, the OR ports will produce, from top down:
0111
1011
1101
1110
But here is the problem, 4066 is a switch. Looking at my numbers I see a zero changing position. But in that case, I would expect the inverse of that, I mean
1000
0100
0010
0001
or a 1 changing position, so this 1 could select one of the four channels of IC3 and IC4 as stated by the 4066 data sheet.
Where is my error?
    \$\begingroup\$ The diagram is incorrect. the CD4001 is a NOR gate, so both inputs have to be logic '0' for the output to be a logic '1'. \$\endgroup\$
    – user105652
    Feb 25, 2018 at 3:06
    \$\begingroup\$ Seems like the cap and resistor across the switch is for debounce rather than for setting the startup state... \$\endgroup\$
    – BobT
    Feb 25, 2018 at 3:39
The diagram is incorrect. The CD4001 is a NOR gate, so both inputs have to be logic '0' for the output to be a logic '1', so your original 'expected' chart is correct. The symbol used in the schematic is wrong. It should have a dot on the output to indicate inversion.
The CD4001 NOR gate is used to make sure only one channel at a time is selected. At power reset, Channel 1 is selected.
This chart is correct, and it is what is taking place in the circuit.
1000 Channel 1
0100 Channel 2
0010 Channel 3
0001 Channel 4
  • \$\begingroup\$ AHHHHHHHHHHH, fantastic! I missed that! THANKS!!!!! \$\endgroup\$
    – Duck
    Feb 25, 2018 at 13:58
