I am new to Electronics. I am trying the Full wave rectifier.
I use a transformer and 4 1n5408 diodes (Vdrop is 1.2V) and try to get 24VDC output from 220VAC 50Hz. I measure the AC output (of the transformer) and it is 24VAC. I measure the output after these 4 diodes, it is about 23VDC.
Everything goes fine until I put the smoothing capacitor, no load yet. It is a 3300uF 25V electrolytic capacitor. When I turn on the power, the capacitor gets hot really fast, changes its shape and is going to explode.
I check the polarity, it is correct. So my question is:
Is it because my capacitor has a "too close" maximum voltage? If it is how should I choose a capacitor voltage for this circuit?
Another question though, I have seen this formula around while searching for my problem: C = I(load)/2.f.V(ripple). So if I need Vr = 2V and I(load) = 2A I need to use a 2/(2.50.2) = 0.01F = 10000uF Capacitor right?
Thank you all, really sorry for my English.
