I have attached the problem with the solution given in my workbook. I attempted the problem and ended up getting a different answer.
Is my solution wrong ?
Please help me to understand the problem.
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityI have attached the problem with the solution given in my workbook. I attempted the problem and ended up getting a different answer.
It's mainly due to rounding errors in the written example. For instance, it calculates a value as being 0.243 but if you do the math yourself it is 0.2437. When they calculate 0.221, it would be more accurate to use 0.2214. When they calculate 0.235 based on those previous values it is closer to 0.236. When you follow it all through you get a value of 0.61345 i.e. very close to what you got.
Beware of rounding errors.
