Background on the issue:
I currently have an SPI bus between an Atmel ATSAM3X8E and a Spansion FL164K flash memory chip.
SPI has always been super reliable for me in past projects, but this design is being very temperamental (the routing is far from ideal). Some boards work fine, some have very occasional data loss in the SPI comms, some have nearly constant data loss. The data loss that I refer to is most easily reproduced by constantly polling the ready flag during a ~50 second erase. Mostly the busy response is 0x03 (0b00000011), but occasionally comes back as not busy - 0x00 (0b00000000).
Fortunately I can reproduce the fault on the bench, and fortunately I can also make the problem go away. Unfortunately though, connecting a passive probe is one of the things that makes the issue go away, so I can't 'see' the fault. And I'm not happy to call it fixed if I am not certain what I am actually fixing.
Circuit design info:
  • The SPI bus is routed to 3 things - SPI flash, SD card (which is not installed), and a basic 6 pin header
  • The red pad in the bottom right is the MCU (clk source), the stub that comes off immediately goes to an n-channel FET which drives an LED, the SOIC8 IC with the red pad is the SPI flash, the 6 pin header above it is unpopulated, and the blue pad at the left side at of the trace is an unpopulated SD card connector.
  • The actual distance from the MCU to the SPI flash is ~35mm, and the SPI flash to the SD card pad is ~30mm. The stub to the FET is ~25mm and the stub to the header is ~8mm.
  • The layout is far from ideal, and I understand that, but the intention was to only run it at <1MHz, so I incorrectly assumed that transmission line theory/terminations/reflections were not needed.
PCB trace layout
Ways that I can already prevent the problem:
  • Add a ceramic capacitor from CLK to ground in the 6 pin header (I have tried values from 18p to 330p). All of them slow the rise time, and the problem doesn't persist
  • Add a 1k resistor from CLK to ground.
  • Attach a scope probe
  • Touch the CLK line with my finger
So basically any way of adding capacitance or loading to the circuit seems to make the reads 100% reliable.
Waveforms (taken with a Rigol DS1054Z with the 100MHz option, and a 150MHz passive probe using a ground spring):
Note: a scope probe is obviously connected for all these (which stops the problem happening). The waveforms we see here are not actually bad enough to cause the problem, but hopefully give an idea of what could be bad enough to cause the issue when the capacitance of the probe is removed.
Note 2: These shots were taken at a 5MHz clock rate, but the problem seems to manifest at anywhere from 100kHz to 20MHz.
On initial inspection the clock signal looks good (albeit very fast ~8ns rise time).
oscilloscope trace showing almost 5 whole cycles of the CLK signal
But a closeup shows a bit of a step halfway up
close-up of rising edge of CLK signal
And at the fastest time scale, this is what I see.
Finally, the questions
  • Is a step in the rising waveform typical of transmission line reflections or something else?
  • Given that the read issue occurs regardless of clock frequency, I assume that the rise time (8ns with probe attached) must be combining with the poor routing to cause the data issues. But don't fast rise times cause ringing, not a stepped waveform? Is it common for a scope probe to dampen ringing that otherwise occurs?
  • Looking at the waveform, what actually happens inside the slave to cause an issue? (the SPI slave double clocks because of that step? or the SPI flash isn't getting it's specified 0.1v/ns slew rate? or something else that I don't understand yet?)
  • Finally, what else could I do to try to assess the signal without loading (fixing) the signal, short of spending $$$ on an active probe that may or may not make a difference?
As you can tell, higher frequency theory is not my area of expertise, so I appreciate anyone's experiences in this area.
Fast rise times will cause lots of crosstalk, as you've mentioned this is independent of frequency. It's hard to see in the image what's traces and what's the grid. Parallel routes, or stacking routes on multiple layers make it worse. As you've done, a capacitor can slow the rise time, but you do need to be careful not to violate set up/hold times.
You may be seeing some reflections due to an impedance mismatch. I've seen source termination used on SPI clock lines to account for this. You want the output resistance plus your source resistor to equal the impedance of your trace.
I'm not familiar with the MCU you're using, but check the datasheet to see if you have any control of the slew rate, you might be able to slow it down. This is common on FPGAs which I'm more familiar with, but I have seen it on some MCUs I've worked with.
  • \$\begingroup\$ Thanks, all valid points. I will be revising the design to add an RC filter at the source (which I will tune for a 25nS rise time, so likely 1kOhm and 12pF), and I'm certain that I will see an improvement. But this relies on the fact that rise time is the cause of the observed problem and not just something that slightly improves it coincidentally. I can't be 100% confident without seeing the problem occurring in the first place. Maybe I should get an active probe, or maybe I'm being a bit too pedantic. \$\endgroup\$ Feb 26, 2018 at 4:07
  • \$\begingroup\$ regarding the other points... I took the guidance of "trace length less than 1/3rd of rise time", and assumed that impedance mismatch would not be a problem. In this case, a 5ns rise time (actually measured @ 8ns with the scope attached) would allow for up to 250mm traces without worrying about impedance matching... Mine is under 100mm in total. So do you think reflections are worth considering even at those figures? Also, I've looked long and hard through the datasheet, but unfortunately this MCU doesn't seem to have slew rate control :( \$\endgroup\$ Feb 26, 2018 at 4:13
