Searching on the Internet, I found that sensor like HC-SR04 can measure from 2 to 300 cm. Other ultrasonic sensors like this starts from 30 cm. Why this difference? ì
  • \$\begingroup\$ Ringing within the piezo element will cause a memory of the transmitter pulse; that ringing must decay to be weaker than any received energy at the 30cm distance. Thus the 2cm system has lots of attention given to dampening. \$\endgroup\$ – analogsystemsrf Feb 26 '18 at 17:41
Another reason why there is a difference in minimum distance is because the waterproof one has only 1 transducer (part that converts ultrasonic to electrical energy and vice versa).
So having only 1 transducer means that the same transducer has to be used for both transmitting and receiving keeping a minimum gap time in between to allow switching from transmitting from receiving mode.
HC SR04 has 2 transducers therefore there is no such limitation.
I was bugged by this limitation too.
I wanted a waterproof ultrasonic sensor with a small minimum distance and I was searching for one and I'm happy that I found out there is a new sensor.
https://www.ebay.com/itm/253978673298
It has 2 transducers instead of 1 so it has smaller minimum detection distance as compared to JSN SR04T.
Also its main board is not exposed like the JSN SR04T since it looks properly sealed and is therefore fully waterproof.
