How is it possible to safely disconnect/turn off an inductor that has current through it without causing a huge backward voltage? Even dropping from a circuit with low current, it the current will still be going from finite to 0, in a very small space of time (how would you calculate this time?), causing a big voltage spike. How can inductors possibly be safe if disconnecting them is so dangerous?
closed as unclear what you're asking by PeterJ, laptop2d, Mitu Raj, Lior Bilia, Dmitry Grigoryev Mar 2 '18 at 20:23
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ Disconnecting from where? \$\endgroup\$ – Eugene Sh. Feb 26 '18 at 21:51
    \$\begingroup\$ Without details, we cannot give you an answer. \$\endgroup\$ – Sparky256 Feb 26 '18 at 22:15
    \$\begingroup\$ You don't normally disconnect components from a circuit while it's operating, so their safety in doing this is irrelevant. \$\endgroup\$ – Finbarr Feb 26 '18 at 22:34
  • \$\begingroup\$ @Finbarr Are you familiar with switches or buttons? Disconnecting components from active circuits is routine. I would wonder how you stop anything from operating otherwise, let alone changing its state. \$\endgroup\$ – Samuel Feb 27 '18 at 22:08
You use a flyback diode.
Knowing the name, you can search regarding your specific application, such as for a relay.
