I'm trying to study an electronic schema based on a LM3914 but I can not find the same threshold voltage, can you help me?
enter image description here Source of the schematic
Components :
IC1=LM3914
D1=1N4007 or equivalent
LD1-LD10=LED
R1=22K, 1/4W
R2=3K9, 1/4W
R3=1K, 1/4W
R4=680 ohm, 1/4W
R5=18K , 1/4W
R6=1K8, 1/4W
C1, C2=10uF/63V
Here is my approach
DETERMINING SIG_IN (Pin5) VOLTAGE
R1 et R2 is a voltage divider so VSIG_IN depend of VBAT (Car Battery)
I substract the 1N4007 forward voltage (1V) I found from the 1N4007 datasheet before applying voltage divider coefficient :
VSIG_IN = (VBAT - 1) * (R2 / (R1 + R2))
VSIG_IN = (VBAT - 1) * (3900 / (22000 + 3900))
VSIG_IN = (VBAT - 1) * 0.150
DETERMINING RHI (Pin6) VOLTAGE
Voltage on RHI is the voltage across R3 plus the voltage across R4 :
VRHI = VR3 + VR4
Internal reference voltage VREF (1.25V) supply constant 1.25V across REF_OUT (Pin7) and REF_ADJ (Pin8) :
VR3 = 1.25 V
We can calculate the current into R3 :
IR3 = VR3/R3
I neglect the current going into REF_ADJ (Pin8) so voltage across R4 is :
VR4 = R4 * IR3
VR4 = 1.25 * (R4 / R3)
So we can calculate VRHI :
VRHI = 1.25 * (1 + (R4 / R3))
VRHI = 1.25 * (1 + (680 / 1000))
VRHI = 2.1 V
DETERMINING RLO (Pin4) VOLTAGE
The internal 10x1K network and R5+R6 is a voltage divider, VRLO depend on VRHI :
VRLO = VRHI * ((R5 + R6) / (10000 + R5 + R6))
VRLO = 2.1 * ((18000 + 1800) / (10000 + 18000 + 1800))
VRLO = 1.39 V
DERTMINING VOLTAGE ACCROSS INTERNAL COMPARATORS
The internal 10x1K network is a voltage divider, the voltage across is :
VRNET = VRHI - VRLO
The voltage across each resistor is :
VR = VRNET / 10
VR = (VRHI - VRLO) / 10
VR = (2.1 - 1.39) / 10
VR = 0.071 V
The voltage across positive input of first comparator (Pin1) is :
VC1 = VRLO + VR
VC1 = 1.39 + 0.071
VC1 = 1.46 V
The voltage across positive input of second comparator (Pin18) is :
VC2 = VC1 + VR
VC2 = 1.46 + 0.071
VC2 = 1.53 V
The voltage across positive input of third comparator (Pin17) is :
VC3 = VC2 + VR
VC3 = 1.53 + 0.071
VC3 = 1.60 V
And so on...
DETERMINING CORRESPONDING BATTERY VOLTAGE
Now we can retrieve the battery voltage corresponding comparators threshold :
VBAT = (VSIG_IN / 0.150) + 1
Where VSIG_IN correspond to threshold VCx
VBATx = (VCx / 0.150) + 1 Like
VBAT1 = (VC1 / 0.150) + 1
VBAT2 = (VC2 / 0.150) + 1
VBAT3 = (VC3 / 0.150) + 1
A so on...
If the voltage on VSIG_IN is upper than threshold (VCx) the corresponding LED is glowing.
PIN   VCx    VBAT
 10   2.10   15.00
 11   2.02   14.47
 12   1.95   14.00
 13   1.88   13.53
 14   1.82   13.13
 15   1.74   12.60
 16   1.67   12.13
 17   1.60   11.66
 18   1.53   11.20
  1   1.46   10.73
PIN  : Is the associated internal comparator
VCx  : Is the corresponding threshold on positive input of comparator
VBAT : Is the corresponding VSIG_IN battery voltage at the threshold
As you see i found about 0.5 V upper than on the schematic and i dont understand why, can you help me ?
  • \$\begingroup\$ Two questions for clarification in your post: (1) The +1 in your formulas: is that the diode drop? It's a bit high. 0.7 V would be better. (2) It's not clear where the table at the end comes from. Are they the results when you test the circuit with a variable voltage power supply? \$\endgroup\$
    – Transistor
    Feb 27, 2018 at 20:50
  • \$\begingroup\$ @Transistor I edit my post to take your good remarks in account, Thank you (1) I found the forward voltage of 1N4007 from datasheet and from guy who take measurement link. (2) The table at the end is the VBAT corresponding to SIG_IN (Threshold) voltage. (3) I wait for LM3914, I could not do measurment, i want to theorically understand this schematic. \$\endgroup\$
    – rom1nux
    Feb 27, 2018 at 21:08
    \$\begingroup\$ You could replace D1 with a 1N5822 Schottky diode. Only a .5 volt drop. The LM3914 is just a string of comparators separated by equal value resistors, so the LED spacing is 'linear'. You could tie R1 before the diode. At 22 K it will limit any 12 volt line overshoot. Use 1% or .1% resistors if you can. \$\endgroup\$
    – user105652
    Feb 27, 2018 at 21:22
  • \$\begingroup\$ Thank you @Sparky256 but i try to understand why i dont find the same result as the creator of this schematic. \$\endgroup\$
    – rom1nux
    Feb 27, 2018 at 22:51
  • \$\begingroup\$ The lm3915 tag should be lm3914. They are NOT the same part. \$\endgroup\$
    – user105652
    Feb 28, 2018 at 0:27
