What is the meaning of the triangle above with "5v" written next to it? is that a ground symbol or an input voltage symbol?
  • \$\begingroup\$ Is this homework? \$\endgroup\$ Commented Mar 1, 2018 at 4:19
  • \$\begingroup\$ No, it is not a homework. \$\endgroup\$ Commented Mar 1, 2018 at 4:27
Here's some hints to what it may be
  • It says 5 V, it does not say \$V_{in}\$
  • it is a constant 5 V
  • \$\begingroup\$ I am new to electronics, but I am guessing the node connected directly to it should be 5v with respect to the bottom ground? \$\endgroup\$ Commented Mar 1, 2018 at 4:25
    \$\begingroup\$ @NegativeTension Yes, it's a way to say this is connected to your 5V supply \$\endgroup\$ Commented Mar 1, 2018 at 4:31
  • \$\begingroup\$ I object to your last bullet. You can have ground pointing upwards, even though it could look strange but I've seen it in textbooks and even at work. Also, you can have this type of connection pointing downwards as well. You can see it on amplifier schematics where the power rail of the amplifier has a downwards arrow (e.g. negative supply rail). \$\endgroup\$
    – user103380
    Commented Mar 1, 2018 at 5:52
  • \$\begingroup\$ @KingDuken I'd prefer some proof, but I've seen.. similar things... so it's not impossible, and that's enough for me to delete that part of my answer. \$\endgroup\$ Commented Mar 1, 2018 at 6:17
  • \$\begingroup\$ @HarrySvensson I'm not trying to negatively criticize :) just wanted to make sure your answer was less ambiguous. \$\endgroup\$
    – user103380
    Commented Mar 1, 2018 at 15:33
The "triangle" is not a part, it is an arrow pointing to the positive (in this case) power supply connection. A positive supply is required for the NPN transistor to operate.
Generally people use signals that look like this for schematics:
It looks like someone threw in a ground signal and then put a label on it, which is confusing, but they did label it 5V so I'd roll with that.
