I am working on a vehicle tracking system that conveys the coordinates information from the vehicle to a server via GPRS communication. For this purpose I am using a GSM module with an arduino uno.
As I was working on this I wondered as to which technique is used in commercial vehicle tracking systems.
Which communication methodology is used in commercial vehicle tracking systems? (Is it GPRS, WCDMA or something else?
  • \$\begingroup\$ So, what have you found - what do Mercedes use for example? \$\endgroup\$ – Solar Mike Mar 7 '18 at 6:45
  • \$\begingroup\$ They generally use the common cellphone system in the region. \$\endgroup\$ – JRE Mar 7 '18 at 6:53
Most vehicle tracking companies use the cellphone network available in the country (i.e GPRS).
For example, using a very cheap GSM module like SIM800, one communicates with the server using a TCP/IP (search WebSockets). This is a common practice. I've seen teardowns of Automatic, CarSense and others.
For Automatic's teardown go to link.
| improve this answer | |
