Sorry if my question is too naive, I'm new to this. I am trying to design a controlled current source for currents up to about 1A (diagram below). My requirement is that the current depend only on the value of a single voltage source and a single resistance (which I can precisely choose).
The problem is that the output voltage of the op-amp = gate voltage of MOSFET is becoming equal to the rail voltage, causing saturation at about 300mA itself (i.e. before reaching 1A). Is there a way I can improve the above circuit to prevent the op-amp from saturating and getting a 1A current?
EDIT: I've changed the design following τεκ's answer and swapped the FET and Load. This should ensure that FET's source voltage doesn't go above 5V, but the gate voltage still goes to 14V and saturates the op-amp. Thanks in advance.
    \$\begingroup\$ What opamp are you using? \$\endgroup\$
    – τεκ
    Mar 7, 2018 at 15:34
    \$\begingroup\$ @τεκ I haven't chosen an op-amp yet, I'm simulating the circuit on LTSpice. I'll later choose a precision op-amp. \$\endgroup\$
    – VP06
    Mar 7, 2018 at 15:48
    \$\begingroup\$ Big, big question - what is the resistance of the load? \$\endgroup\$ Mar 7, 2018 at 15:55
  • \$\begingroup\$ Thanks, I just realized R(load) matters a lot in my design above, but it shouldn't in @τεκ's answer (swap FET and load), however that still doesn't help. I'm going to edit my question for that. \$\endgroup\$
    – VP06
    Mar 7, 2018 at 15:58
    \$\begingroup\$ @QMrules that's your problem - the load value is too big as per my answer. \$\endgroup\$
    Mar 7, 2018 at 16:09
With a 5 ohm sense resistor and a 5 volt control signal you will get 1 amp through the load if the load's value of resistance is low enough. For instance, if the load is 10 ohms then you need 15 volts at the source of the MOSFET to drive 1 amp through 10 ohms plus 5 ohms.
Plus you need another 2 to 10 volts more on the gate to get enough conduction (generalism alert) through the MOSFET. So, given your values, even if the load was zero ohms, you will need a supply voltage that is at least 7 volts and more likely 10 to 15 volts. This assumes the op-amp output is rail-to-rail.
I will note that you have shown V2 as 1 volt and this could only ever push 200 mA through 5 ohms.I assume this is an error on your part as is not putting a ground symbol at the bottom of R1.
  • \$\begingroup\$ Thanks, I understood why it's happening.. @τεκ's answer puts the load above the FET, so the source voltage is now at most 5V. This is still not solving the issue, and the gate voltage shoots up rapidly from 4V onwards and op-amp saturates.. I'm unable to see why.. \$\endgroup\$
    – VP06
  • \$\begingroup\$ Op-amp power supply voltage? Op-amp? Load resistance? Possibly 45 ohms? \$\endgroup\$
    Mar 7, 2018 at 16:04
    \$\begingroup\$ You can't push 1 amp through a 50 ohm load if the supply is only 15 volts. \$\endgroup\$
    Mar 7, 2018 at 16:08
  • \$\begingroup\$ I've chosen 15V supply voltage for op-amp and LM741 for simulation. Load resistance would be 50ohm at max. \$\endgroup\$
    – VP06
    Mar 7, 2018 at 16:18
  • \$\begingroup\$ Thanks a lot! Now I understand why it's not working. \$\endgroup\$
    – VP06
    Mar 7, 2018 at 16:24
Swap the load and MOSFET.
  • \$\begingroup\$ It's not working.. The gate voltage again shoots up to 14V, and saturates the op-amp.. \$\endgroup\$
    – VP06
    Mar 7, 2018 at 15:51
  • \$\begingroup\$ I think you might be missing a ground on the bottom of R1. \$\endgroup\$ Mar 7, 2018 at 15:59
  • \$\begingroup\$ Sorry, that was my fault. I've edited the schematic in the question. \$\endgroup\$
    – VP06
