-1
I have to create a two level circuit NAND only gates for the Fibonacci from 1-8. After creating a truth table and K-Maps, I got the Function F=A'B + B'C. Then I drew the AND-OR circuit and tried to convert it NAND only circuit. After implementing it on our bread board, I did not get the correct output, so I am guessing something is wrong with my circuit diagram. I am not sure. For the truth table that we were given, the directions given were:
Each row in the truth table is identified by a decimal number. For each row that corresponds to a Fibonacci number, specify the output to be 1. Otherwise, specify the output to be 0.
Truth table
K-Map
Circuit Diagram
  • \$\begingroup\$ Do you understand what the Fibonacci sequence is..... \$\endgroup\$
    – Trevor_G
    Mar 7, 2018 at 20:44
    \$\begingroup\$ In States 4 to 7, A should be 1. Which makes your truth table so wrong. But you have a correct term \$\bar B C\$, even though K-map is wrong. \$\endgroup\$ Mar 7, 2018 at 21:34
  • \$\begingroup\$ The truth table is the one we received, we had to fill in the Fib.Num column. So when the minterm number is within the Fibonacci sequence, then we put a 1 in that column, else put a 0. The original truth table was from 0-15 so the last 8 rows were all 1s, but for this one, it has to be from 0-7. We just cut the table in half \$\endgroup\$ Mar 7, 2018 at 21:48
    \$\begingroup\$ When you cut the truth table in half, you took the wrong half...because your truth table can't be true. \$\endgroup\$
    – Annie
    Mar 7, 2018 at 22:08
    \$\begingroup\$ On two occasions I have been asked, — "Pray, Mr. Babbage, if you put into the machine wrong figures, will the right answers come out?" -Charles Babbage \$\endgroup\$
    – Annie
    Mar 7, 2018 at 22:23
You can use the De Morgan theorems to convert any OR logic to AND and vice-versa:
!(A * B) = !A + !B
and
!(A + B) = !A * !B
