10
I'm looking into using the LT3759. One of the features that they advertise is frequency foldback.
Frequency Foldback
When VOUT is very low during start-up or a short-circuit fault on the output, the switching regulator must operate at low duty cycles to maintain the power switch current within the current limit range, since the inductor current decay rate is very low during switch off time. The minimum on-time limitation may prevent the switcher from attaining a sufficiently low duty cycle at the programmed switching frequency. So, the switch current will keep increasing through each switch cycle, exceeding the programmed current limit. To prevent the switch peak currents from exceeding the programmed value, the LT3759 contains a frequency foldback function to reduce the switching frequency when the FBX voltage is low (see the Normalized Switching Frequency vs FBX graph in the Typical Performance Characteristics section). Some frequency foldback waveforms are shown in the Typical Applications section. The frequency foldback function prevents IL from exceeding the programmed limits because of the minimum on-time.
For the following example application circuit that they include,
Example schematic
they provide a plot of the frequency foldback waveforms.
Waveforms
This seems different from foldback short circuit protection. But how does frequency foldback work? What would be a good analogy to its process? What would the plot look like without frequency foldback?
I also haven't noticed a frequency foldback feature in other switching regulator datasheets, so how important is this feature?
Frequency foldback as shown above is simply reducing the switching frequency.
If the switcher is running at the minimum ON time but the inductor current is still rising (the inductor will actually discharge more slowly if there is a heavy load), then the only option left is to reduce the frequency.
You can see on the waveforms when the output voltage drops to 0V, the switching waveform (Vsw) reduces it's frequency. Also note the discharge slope of the inductor is more shallow (bottom waveform)
  • \$\begingroup\$ What was the downvote for? \$\endgroup\$ – Oli Glaser Jul 18 '12 at 21:24
  • \$\begingroup\$ No idea, I thought it was a good answer. You got a +1 from me regardless. \$\endgroup\$ – Polynomial Jul 19 '12 at 14:16
THis is basically a soft start at 40% of the switching rate until it reaches a threshold then it operates at designed speed. If overcurrent drops the voltage it folds back switching freq to 40% until the fault is removed. THis reduces input current at the same time.
It is like an engine turbo that runs at low RPM until the engine reaches 6000 RPM then it speeds up to regulate to the load demand. It changes faster with reverse voltage on the output to slow down the pulse rate.
THis is an over-load soft start and auto recovery design feature.
For loop stability it would be seen as lowering the loop gain, which remains stable.
