I am a beginner attempting to learn how to hack RC cars like is demonstrated in this video.
My problem is I can't spot the ground pin and the other pins related to the wheel drive functions except I randomly test pins with my multimeter.
In an old pair of RC cars, after a long time of trial and error I finally located the ground and one of the pins connected to a wheel.
However, I just wonder if there is a technique for locating ground and other pins in a circuit, please?
I want to learn how to locate the relevant pins so I can hack these cars.
    \$\begingroup\$ The "ground" is usually connected to the - terminal of the battery. Then you just check continuity with that point. \$\endgroup\$ – Eugene Sh. Mar 8 '18 at 17:59
  • \$\begingroup\$ data-sheets for the parts involved will also indicate ground... the black wire to the servo is ground... \$\endgroup\$ – Jasen Mar 8 '18 at 19:28
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
