I am having a hard time to calculate the baud rate for the following:
Needed baud rate for 2 bytes data at 1KHz over an UART port with a 8N1 protocol
Thanks
    \$\begingroup\$ what is " 2 bytes data at 1KHz " ? Do you mean you need to transmit 2 bytes of data every millisecond? \$\endgroup\$ – Eugene Sh. Mar 9 '18 at 21:26
2 bytes at 1kHz at 10 bits per byte = 1,000 * 2 * 10 = 20 kbit/second
So your minimum, standard, baud rate would be 38,400.
