I'm using this famous logic analyzer and I would like to know if I can change the waveform into binary, like I've done in this pic (white numbers).
\$\begingroup\$ yes, you have to enable the protocol analyzer for that data stream ... it is on the right side of the screen \$\endgroup\$– jsotolaMar 11, 2018 at 4:11
2\$\begingroup\$ If you operate it with sigrok (and maybe pulseview) instead of the Saleae software you can write your own protocol decoders in python, or pipe the data into something in the language of your choice. \$\endgroup\$– Chris StrattonMar 7, 2019 at 19:09
\$\begingroup\$ Logic (the app) isn't going to know the relationship between your waveforms unless it's defined somehow - which is clock, which is data, when data should be read (rising edge/falling edge) with respect to the clock, so no there will be no heurestic decoding of this signal in my estimation. \$\endgroup\$– Adam LawrenceMar 19, 2020 at 14:06
\$\begingroup\$ @ChrisStratton nice - I wrote an analyser in C++ with the salae sdk but didn't know python was also possible - oooh! \$\endgroup\$– danmcbApr 15, 2021 at 9:14
Your channel labels (MISO, Clock, CS) are perfectly consistent with standard SPI protocol. Just add an SPI analyzer and assign your rows accordingly:
- MISO <- MISO
- Clock <- Clock
- Enable <- CS
You'll probably have to play with the polarity (CPOL) and phase options (CPHA) to get it to match your particular signal.
You can add a protocol analyser from the centre of the right-hand panel. It will software-decode the waveforms into packets of whatever protocol you are investigating. From there, you can specify the radix as binary to get a binary output.
If you are looking at arbitrary waveforms, I'm not sure the software will reliably decode it. But at that point, a protocol analyser couldn't tell you any more than simply looking at the screen!
\$\begingroup\$ I know that, but this it not any standard protocol. I just want to get the binary code from a data line according to a clock line. I think there's no protocol analyzer for that, right? \$\endgroup\$ Mar 11, 2018 at 14:31
