I am trying to simulate a differential per-driver stage for a laser driver in ADS. i want to use pulse signal to the input, but the voltage source doesnt give the option to change phase like AC voltage source. how do you generate a pulse signal with phase shift? enter image description here
  • \$\begingroup\$ Can you mathematically describe what a "pulse signal with a phase shift" is? As in \$s(t) = \ldots\$? I'm not sure what you're expecting! \$\endgroup\$ – Marcus Müller Mar 11 '18 at 15:08
    \$\begingroup\$ You use delay, rather than phase. \$\endgroup\$ – WhatRoughBeast Mar 11 '18 at 15:10
  • \$\begingroup\$ I am trying to simulate a current steering circuit which has differential transistors. so to switch the mosfets i have to use pulse source right? and do i need to apply sources to each differential input or a single floating voltage source can work? \$\endgroup\$ – Muiik Ryo Mihawk Mar 12 '18 at 11:11
