There's Pin as both input (for a switch) and output (for LED) with ATmega32U4? but I also need one of six such pins to drive a piezo buzzer. Due to its capacitive nature, I figured it could be connected to the GPIO as well (has no effect on DC signals):
The idea was to suppress the noise, that would likely originate from switching the GPIO from output-low (to drive the LED) to input-pull-up (for sampling the pushbutton), using a high pass filter with an "odd" 1.5 kHz or so, so sampling at 100 Hz or so does not affect the 4 kHz piezo as much.
Drawbacks (both are acceptable):
  • pushing the button lights the LED (and dumps C1's charge to ground; maybe add a series resistor?)
  • driving the piezo with a 4 kHz square wave lights the LED at 50 % (maybe this can be a lower duty-cycle due to the filter?)
Does this work and can it be improved?
  • \$\begingroup\$ how fast do you need the LED to turn on or off? \$\endgroup\$ Mar 12, 2018 at 14:00
  • \$\begingroup\$ @MarcusMüller It's just a status LED for humans: visible frequency for blinking would be in the 1 Hz range, so the transition should not take longer than maybe 0.1 s. \$\endgroup\$
    – handle
    Mar 12, 2018 at 14:20
  • \$\begingroup\$ See LED and Button Matrix multiplexing? for a different approach to possibly work around too few pins in the same situation. \$\endgroup\$
    – handle
    Mar 12, 2018 at 14:27
You can of course, instead of directly driving the LED, add a high-impedance low pass filter, driving a thresholding element (e.g. a transistor, a comparator with a reference, or an elegantly connected diode), which in turn drives the LED.
                                     +3.3V
                                       R
                                      LED
     +----High Pass----Piezo---GND     |
GPIO-+----------------Switch---GND   |/
     +----R_large---+----------------|
                    C                  v
                   GND                GND
