I have designed the following optoisolator for SWD interfacing with an STM32 device and J-LINK programmer:
This is the generic schematic: enter image description here
And this is a single optoisolator schematic: enter image description here
I am not able to interface with the board in the J-Link commander. I see that J-Links attempts to reset the device but fails to communicate. Is there any basic flaw in my design? Can the bidirectional SWDIO line be the case? I would appreciate all help.
    \$\begingroup\$ Out is inverted from In . Is that OK? \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Mar 12 '18 at 15:02
  • \$\begingroup\$ Yes. When LED is ON, the out is LOW. When LED is off, out is high. \$\endgroup\$ – Łukasz Przeniosło Mar 12 '18 at 16:23
  • \$\begingroup\$ Please explain the resistor values. (All of them appear to be too low.) \$\endgroup\$ – CL. Mar 12 '18 at 17:53
  • \$\begingroup\$ R3 is the closesest one for 10 mA LED current. R5 is from datasheet test circuit design. R1 and R2 are the same as R3, just to have them at hand. I did not want to force any high instantaneous current on the bidirectional patch. Do you have any idea what could be the case? \$\endgroup\$ – Łukasz Przeniosło Mar 12 '18 at 17:54
  • \$\begingroup\$ What do you see on the STM32 side on SWDIO? You should see the switching sequence, and a target ID read, followed by an ACK (1+3+1 bits), 32 bits data and parity. This much progress occurs mastered by the J-link, and the ID read needs to be seen to show the target is present. \$\endgroup\$ – Sean Houlihane Mar 26 '18 at 20:19
Yes, you're right X5 and X6 are making a positive feedback loop. You need a bidirectional optoisolator for SWDIO line. For speeds up to 1 Mhz you can find guidance in this NXP Application note. You also need to see if the 160 ns delay induced by the optocouplers (2x80ns,forward path + backward path) is acceptable for the programmer. You might want to change the point of view and insulate the USB side of the programmer with a device like USB ISO form Olimex
|improve this answer|||||
  • \$\begingroup\$ Thanks for answer. I ended up using Si8605 eventually. Simplified the whole design. \$\endgroup\$ – Łukasz Przeniosło Apr 2 '18 at 8:21
  • \$\begingroup\$ Good to know. I didn't know if it's a one time solution for a particular issue or a product that you want to sell having cost constraints. For a one time design USB ISO interface is much expensive but gets the maximum speed from the programmer. The opto or Si8605 add some delays in the signals. \$\endgroup\$ – Dorian Apr 2 '18 at 14:22
