For some reason my pin change interrupts are not triggered on my Atmega324PB. To test, I'm using an eval board and connecting an output pin to a pin configured to trigger a pin change interrupt. Is there something I'm missing?
volatile uint16_t motorCount = 0;
// Configuring pin change interrupt on A7.
// A7 pin change interrupts are handled in
// "pin change interrupt request 3"
PCICR |= (1 << PCIE3);
PCMSK3 |= (1<<PCINT31);
// Interrupt routine
ISR(PCINT3_vect)
  motorCount++;
To test, I've wired it to an output pin, A2. I have verified with a multimeter that pin A2 and A7 are changing from low (0V), to high (~3.6V). This change doesn't trigger the interrupt. It doesn't trigger when changing back to low either.
// main.c
__enable_interrupt();
uint8_t test = 0;
DDRA |= (1 << DDRA2);   // A2 as output
while (1) {
    if(kbhit())  // Wait's for serial input character (configured separately)
        if(('\n' == tmp) || ('\r'== tmp))
            test ^= 1; // Toggle first bit.
            test &= 1; // Mask to only first bit.
            if (test == 1) {
                // output high on A2
                PORTA |= (1 << PORTA2);
            else {
                // output low on A2
                PORTA &= ~(1 << PORTA2);
It turns out I misinterpreted the data sheet!
In this line in section 15.1...
"The Pin Change Interrupt Request 3 (PCI3) will trigger if any enabled PCINT[31:24] pin toggles."
I thought "PCINT[31:24]" was referring to pins 31 to 24. I missed the fact that there were pins defined as PCINT31, PCINT30, PCINT29, ..., PCINT24. For the atmega324pb, PCINT31 is the same pin as D7, as pointed out in the comments.
    \$\begingroup\$ "It turns out there is an error in the Atmega324pb datasheet!" - where is the error? ww1.microchip.com/downloads/en/DeviceDoc/40001908A.pdf Table 16-12. port pin PD7 alternate function PCINT31 \$\endgroup\$ Commented Mar 13, 2018 at 4:46
  • \$\begingroup\$ I just realized the mistake was in my interpretation. I interpreted the "PCINT[31:24]" as pins 31 to 24. Thanks! I'll update the answer to point out my misinterpretation, in case someone else is as hasty as myself and misses that glaring detail. \$\endgroup\$
    – Scampbell
    Commented Mar 13, 2018 at 16:37
