I've got a LCD driver board (with some push buttons to open menu/+/-) and a bi-directional HDMI switch (with a latch button to redirect HDMI output to one or another) where I want to remove those buttons and command them via a teensy 2+ I bought. Do I just need to wire board GND and switch GND to teensy and do: (let set PIN_D5 is connected to the lcd board button menu and PIN_D6 to the latch button)
In loop function:
pinMode(PIN_D5, OUTPUT);
digitalWrite(PIN_D5, LOW);
digitalWrite(PIN_D5, HIGH);
to simulate a momentary push
and
pinMode(PIN_D6, OUTPUT);
digitalWrite(PIN_D6, LOW);
to simulate a maintained push ?
Declaring pin modes should remain in the setup function, as it shouldn't change during the program.
Also, you can keep the button state in a variable and change it later as you simulate a push :
bool btnState = false;
setup(){
void switchButton(){
  btnState = !btnState;
  digitalWrite(PIN_D6, btnState);
[EDIT]
If you want to simulate a momentary pushed button, you may need to wait a little while between pressing and releasing a given button as below :
void pressButton(int button){
  digitalWrite(button, HIGH);
  delay(100);
  digitalWrite(button, LOW);
NB : depending on your LCD driver board logic, you may need to change HIGH level to LOW and vice-versa
  • \$\begingroup\$ thank you for your answer, pinMode must be in setup you're right. I can then simulate every push button just by using digitalWrite then ? \$\endgroup\$
    – Frntz
    Commented Mar 15, 2018 at 13:53
