I am trying to design a PCB for a wireless Thermometer using the RFM69CW Radio Module and the ATMega328p as an MCU. I placed the MCU and the RFM69CW back-to-back on my PCB and routed all the connections, however I am unsure what to do with the antenna line.
While prototyping the setup on a breadboard i simply soldered a 1/4 wavelength (865 MHz) monopole wire antenna to the antenna pad of the RFM69CW modules and everything worked fine.
However now I read a lot about RF Design and I am completely unsure what I should or shouldn't do.
I originally intended to simply route a standard trace from the ANT pad of the module to a plated trough hole and then solder my wire antenna to the hole. However, I read in several places, that i have to match the impedance of the trace to 50 Ohm and that i also have to put a ground plane next to or under(?) the trace.
What is the best way to add a simple wire antenna to my PCB design? I already saw designs like the Aaduino or the Moteino from LowPowerLabs that just connected a plated trough hole some millimeters away from the ANT pad of the RFM69CW and put a ground plane on the other side of the PCB. Is it that simple or are there certain calculations behind these designs?
Attached is my design, the trough hole on the top left is my current attempt for mounting the wire antenna.
