I want to realize a wireless keypad using ESP-32 and a matrix 4x3 keypad, connected via Bluetooth Low Energy to a master unit. I want to use deep sleep mode of ESP-32 when the keypad is not used but I need to wake up the ESP when a key is pressed, while not loosing the input. As far I understood, the matrix keypad needs the CPU running in order to understand which key has been pressed. Is there maybe some other way or component that I can use for this? Thanks for your suggestions.
There is a possibility to use lo power mcu that is build in the esp32 for reading the input while main cores are in deep sleep, but as far as i have been using it only with touch keypad.
It's not a full answer, but should help You.
https://www.espressif.com/sites/default/files/documentation/esp32_datasheet_en.pdf
Page 5, RTC block with ULP co-processor
also: https://github.com/espressif/esp-idf/tree/master/examples/system/ulp
https://blog.adafruit.com/2018/02/20/deep-sleep-tutorial-for-esp32-using-the-rtc-ulp-co-processor-and-two-lines-of-code/
This can handle the keypad feauture with wakeup for main core.
Hope it helped.
  • \$\begingroup\$ Welcome to electronics.stackexchange.com. Keep up the good work. \$\endgroup\$
    – Maple
    Commented Jun 17, 2018 at 8:35
  • \$\begingroup\$ No problem, without help of others on this and many other forums or websites i would not have the knowledge I have. So if there is a way to give back to others what i have received when needed, i'm always willing to help. That's what community stands for, right? :) \$\endgroup\$ Commented Jun 20, 2018 at 23:54
