I am using a STM32F415RGT6 embedded in the 1Bitsy Board. I want to set up the I2C Peripheral in order to read some data from a sensor. I am using the stm32f4 standard peripheral library.
My example code:
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);
GPIO_InitTypeDef gpioInit;
GPIO_StructInit(&gpioInit);
gpioInit.GPIO_Mode = GPIO_Mode_AF;
gpioInit.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
gpioInit.GPIO_PuPd = GPIO_PuPd_UP;
gpioInit.GPIO_Speed = GPIO_Speed_25MHz;
GPIO_PinAFConfig(GPIOB, GPIO_PinSource6, GPIO_AF_I2C1);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource7, GPIO_AF_I2C1);
GPIO_Init(GPIOB, &gpioInit);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1, ENABLE);
I2C_DeInit(I2C1);
I2C_InitTypeDef I2C_InitStructure;
I2C_StructInit(&I2C_InitStructure);
/* I2C configuration */
I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
I2C_InitStructure.I2C_ClockSpeed = 100000;
I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;
I2C_InitStructure.I2C_OwnAddress1 = 0x01;
I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
I2C_Init(I2C1, &I2C_InitStructure);
I2C_Cmd(I2C1, ENABLE);
while (I2C_GetFlagStatus(I2C1, I2C_FLAG_BUSY));
/* Generate Start, send the address and wait for ACK */
I2C_GenerateSTART(I2C1, ENABLE);
while (!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT));
I2C_Send7bitAddress(I2C1, 0xE0, I2C_Direction_Transmitter);
while (!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
After that I want to write a 0x00, but the code always hangs in the last line, apparently the Master never reads the acknowledge. The I2C status registers always read:
I2C1 -> SR1 = 1024
I2C1 -> SR2 = 3
which means that the Acknowledge Failure bit is always set. If I analyze it using my Saleae I get the following:
The Slave sends the ACK, but the STM32F415 cannot read it.
The weird thing: If I try the same code on my F407 - Disco (only with clock set to 400khz, but it's the same behaviour on both MCUs regardless of Speed), it works flawlessly:
All other peripherals work fine. I already tried several workarounds, but the AF bit is always set, regardless of method. I hope you can help me.
P.S: I have tried with and without additional pullups and the I2C Slave Address is fine, because it works with STM32F0, STM32F4-DISCO and Atmel Mcus.
Best Regards and Thanks in advance!
should begpioInit.GPIO_PuPd = GPIO_OType_OD;
with pull-ups. \$\endgroup\$ – Abel Tom Mar 14 '18 at 12:130xE0
then you need to pass the eight bit address to the APII2C_Send7bitAddress(I2C1, uint8_t(0xE0<<1), I2C_Direction_Transmitter);
but im strongly guessing it is 0x70 and you already shifted it \$\endgroup\$ – Abel Tom Mar 15 '18 at 7:03
