I see in buck converter examples that they have fixed/regulated input voltage and a fixed output.
I'm planning to build or buy a for example 9V to 5V buck converter but the 9V side will be composed of parallel batteries. This means the input voltage will not be regulated. And since the battery voltage will drop by time output voltage will be affected proportionally if I use a buck converter.
Is there a DC DC converter or a type of buck converter which both steps down the input voltage and also regulates it to a reference value? Like in my case the input voltage is not regulated(batteries) but the output voltage must regulated to a fixed voltage.
Well, a buck regulator will work fine with a range of input voltages after all, it wouldn't be much of a regulator if it required a constant input voltage.
No, it's a regulator and produces a regulated output. There are some caveats but generally I think your research into buck regulators is flawed.
Yes, pretty much all of them. Here's an example: -
It will produce 5 volts (at up to 1 amp) at the output with input voltages ranging from 6.5 volts to 100 volts.
  • \$\begingroup\$ There is no feedback in buck converter examples how would they regulate? See this example i.stack.imgur.com/VBLN4.png Is "buck regulator" you mentioned a different thing than a "buck converter"? \$\endgroup\$
    – GNZ
    Mar 14, 2018 at 10:07
  • \$\begingroup\$ A proper regulator uses feedback to maintain the output voltage within prescribed limits. What your picture shows is the basic circuit mechansim that is used to efficiently reduce voltage with minimal power loss. \$\endgroup\$
    Mar 14, 2018 at 10:10
  • \$\begingroup\$ I see now. Thanks for this example. Seems I can build it myself, for battery to 5V conversion. \$\endgroup\$
    – GNZ
    Mar 14, 2018 at 10:11
  • \$\begingroup\$ There are plenty of devices out there to do what you want. \$\endgroup\$
    Mar 14, 2018 at 10:12
You can use an 7805 Voltage Regulator IC, which converts anything from (max) 40 (I believe) V to 5 V.
It will dissipate heat, so if the difference is too high (like 9 to 5 V) AND you are using a lot of current, you need a heat sink.
    \$\begingroup\$ The thing is I dont want to use a linear regulator. Because they are not efficient. \$\endgroup\$
    – GNZ
    Mar 14, 2018 at 10:03
  • \$\begingroup\$ Is there a regulated output DC DC converter? \$\endgroup\$
    – GNZ
  • \$\begingroup\$ Understandable (since you use batteries), maybe good to add in your question as a requirement. \$\endgroup\$ Mar 14, 2018 at 10:04
    \$\begingroup\$ It is already written two times \$\endgroup\$
    – GNZ
