tl;dr: I want to run a 120mm case fan (drawing 0.05A) off my router's USB port, and don't know whether to be concerned about running a DC motor off a sensitive box full of radios.
The CPU in my (ASUS RT-AC3200) Wi-Fi router has a tendency to self-report temps of 70°C and higher when working hard.
Because of my (admittedly potentially unfounded) concern about that temp, and because I like to tinker, I tried sitting the router atop a garden-variety 120mm case fan (marked 12V 0.16A), which I fed just 5V to keep it slow and quiet.
The router temp soon dropped to 57°C, which I like much better.
My cheapo meter tells me the fan draws 0.05A when fed 5.33V.
Given the installation of the router, it would be quite handy to power this fan off the router's USB port.
Though I don't know the USB port's specs, a current draw of 0.05A doesn't strike me as troubling--I know it will fundamentally "work."
What does give me pause, though, is putting a motor on the power bus of a box of sensitive radios, for fear of generating problematic electrical noise or causing other woes.
Should I avoid this? Or am I being paranoid?
    \$\begingroup\$ So, when there are dual cooling fans sold for laptops powered from the usb bus - I would suggest no, there is no problem. \$\endgroup\$ – Solar Mike Mar 14 '18 at 16:56
    \$\begingroup\$ a USB port can safely provide 5V at 0.5A \$\endgroup\$ – jsotola Mar 14 '18 at 17:48
  • \$\begingroup\$ @SolarMike, I hear where you are coming from, but those Chinese factories turn out all sorts of technology and health products that are unwise, in practice. Also, I don't base the communication infrastructure of my entire house on one laptop, whereas in the case of my router, I do. I'll add clarification that it is electrical noise that concerns me. \$\endgroup\$ – bland328 Mar 14 '18 at 17:51
    \$\begingroup\$ @AliChen From 7.2.1: "Ports that can supply only one unit load are termed low power ports." - There is no requirement for all host ports to be able to provide 5 units. Low power ports are allowed by spec to only provide 1 unit. "High-power functions ... They must draw no more than one unit load upon power-up and may draw up to five unit loads after being configured." - Devices aren't allowed to draw 5 units unless configured. \$\endgroup\$ – Tom Carpenter Mar 14 '18 at 22:00
    \$\begingroup\$ @bland328 and have you checked how many other components are from chinesium factories in all your kit.... \$\endgroup\$ – Solar Mike Mar 14 '18 at 22:13
All USB hosts must however be able to provide 100mA by default, so in terms of current you should have no issues.
However, fans are inductive and could produce back-EMF when the power switches off. This is basically a high voltage spike that will feed back into the USB port. Depending on how well protected the port is, this shouldn't be an issue. I would personally place a diode in anti-parallel with the fan (anode to GND). This will add some additional protection.
Another potential issue is that if the fan stalls, you may get a current surge as a result because the fan is basically just a DC motor, and current could rise rapidly under stall condition. This is likely not an issue with higher quality fans. Placing something like a 15Ω resistor in series between the 5V and the fan will limit the maximum current that can be drawn in the event of a stall. It will cause ~0.5V drop under normal conditions, but this shouldn't be an issue for the fan.
As a final point, the fan will generate electrical noise. I would personally place something like a 10μF capacitor across the USB +5V/GND pins. This in combination with the 15Ω resistor will act as a low pass filter, limiting the amount of noise that gets back into the device from the motor.
Something like this should suffice:
Investigation - Akasa AK-183-L2B 12V 120mm Fan
So I though I would do a quick investigation with a branded (£8) fan, to see if my points about noise and filtering, quote "... are unfounded" (@AliChen)
So here is my PSU. I'm loading it with a ~33mA pure resistive load, which is an equivalent current draw to the fan:
PSU Output, 33mA DC Resistive Load
Not bad I think you would agree. Regulating nicely, with ~40mV ripple/noise.
Now lets connect the fan. The fan draws roughly 33mA from the PSU, and is spinning happily.
PSU Output, 33mA Akasa Fan
There are now period spikes pulsing up to ~5.5V, with a large amount of ripple and noise (~200mVpp). I personally don't want that anywhere near a USB port.
Now lets put a capacitor across it:
Fan Connected, Parallel Capacitor
Not bad, filters out a lot of the mess.
Now with a series resistor as well, same circuit as in the main answer above (minus the diode). I'm probing on the power supply side.
Fan Connected, Parallel Cap, Series Resistor
Even better. The spikes are cleaned up to ~70mVpp, and the noise is pretty clean.
As another point of interest, this particular fan draws about 55mA in a stall condition, so not too bad.
  • \$\begingroup\$ Ahhh...there's nothing like hearing from an engineer! This is terrific. Thanks very, very much, Tom. \$\endgroup\$ – bland328 Mar 14 '18 at 19:17
  • \$\begingroup\$ This is quite wrong and way over-engineered. First, normal USB ports provide no less than 500 mA. Second, PC case fans are brushless, and already have proper EMF protection inside, so they don't produce much spikes. Third, when stalled, they don't have nearly-short conditions as brushed DC motors do; more, they automatically shut their internal electronics down when stalled. Just make sure that the fan doesn't stall at voltages below 5 V, say, at 4 - 4.3 V. If it starts spinning more or less reliably at 5 V, just plug it in. Sorry Tom, -1. \$\endgroup\$ – Ale..chenski Mar 14 '18 at 20:50
    \$\begingroup\$ @AliChen I urge you to buy a cheap fan off eBay for £2. Let me know how well engineered it is and how it has proper EMF protection. It may be overkill for proper spec PC fans, but there's a load of cheap rubbish that lacks any sort of protection. If it were my £200 router, I'd happily spend 50p on three passive components. \$\endgroup\$ – Tom Carpenter Mar 14 '18 at 22:05
  • \$\begingroup\$ @AliChen The point about stalling at voltages below 5V is valid for a 5V rated fan, but given the op has a 12V rated fan, whether it works at 5V or 4.5V or 4V is pure luck anyway. \$\endgroup\$ – Tom Carpenter Mar 14 '18 at 22:06
    \$\begingroup\$ By all means, write an answer of just "Plug it in and all will be fine", let the voting decide. \$\endgroup\$ – Tom Carpenter Mar 14 '18 at 22:07
The ASUS RT-AC3200 gigabit router has USB 2.0 and USB 3.0 ports. As a self-powered device, the ports should be expected to deliver no less than 500 mA of current from USB2 port, and 900 mA from USB3 port. This is in accord with Section 7.2.1 of USB 2.0 specifications, which reads in part: "Systems that obtain operating power externally, either AC or DC, must supply at least five unit loads to each port." Therefore it should be of no concern to take 50 mA out of any of these ports.
Then, modern PC case fans are built on brushless technology, with a driver IC that uses magneto-sensitive index sensors, and then pulses internal stator windings accordingly to make the fan's blades to spin. A typical motor driver IC application is:
Due to massive deployment of fans in PC industry and associated potential liabilities from mechanical failures, the technology has developed fairly sophisticated methods to prevent electrical problems. The controllers (and internal boards) in PC fans have all sorts of protection against EMI, temperature, stalls, etc. The ICs would usually shut itself down if the rotor blades are not spinning.
Many manufacturers guarantee a 12-V fan operating range from 6 to 18 V, example is here.
Therefore operating a 12-V fan at 5 V is not far away from main specifications, and is frequently used in "silent PC" designs by DIYers. It is however advisable to check if the particular fan has any margins in this mode. This can be checked either using a variable benchtop power supply and dropping the voltage until the fan no longer starts, or just stalling the blade and making sure that the spin starts "happily", softly speaking.
Further, a USB port is required to have a sizable bypass capacitor on each USB host port. An example of the bypass from design guidance is shown below
Furthermore, in case of several USB ports, design recommendations are to use separate bypass caps on each port, and de-couple them from main power source with inductive filters,
This technique is required to avoid so-called "droop" effect, when a hot plug of a device in one port might cause power interruption for a device working in another port. Without this de-coupling a USB host would fail USB-IF certification. Therefore, any possible interference on power at one port is unlikely to penetrate internals of USB host and disrupt USB or any radio functionality.
In conclusion, just plug your fan into any of USB ports of your router, and, if it spins "happily", don't worry much.
