Please suggest if the layout is fine:
- it is 25MHz 3225 crystal.
- I maintained short traced for XIN and XOUT.
- I maintained a guard ring around the crystal.
- I have grounding in layer just below.
- the dotted shape is also ground.
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityPlease suggest if the layout is fine:
It looks good. 25 MHz is not amazingly fast, you can probably get away without the ring.
As a rule of thumb, things start to get a little scary above 100 MHz, a 25 MHz crystal is "easy".
