Regarding this instructable , why is it possible to build this circuit without transistors?
We have 4 layers of LEDs like that, which is controlled by an Arduino.
Every circle is a LED, the blue arrows are connections to ground (individual pins set to LOW on the arduino when the LED should turn on).
And there's 1 connection to a HIGH pin on each layer with a 100 Ohm resistor.
In total 16 Pins for the ground connections and 4 Pins for each layer (VCC).
This code turns all LEDs on 1 layer on.
////////////////////////////////////////////////////////////turn all on
void turnEverythingOn()
for(int i = 0; i<16; i++)
digitalWrite(column[i], 0);
//turning on layers
for(int i = 0; i<4; i++)
digitalWrite(layer[i], 1);
So when everything is turned on, each layer pin has to drive 16 LEDs, this will result in a higher current load than what the atmega chip on the Arduino can supply. At least this was my original question / concern.
My original understanding was that there are 4 LEDs in series (one vertical red line connecting 4 LEDs) and that each of these 4 lines are in parallel.
As already has been pointed out in the answers / comments, the 16 LEDs are actually in parallel.
The calculation for the resistor was made via 2 V / 0.02 A = 100 Ohm.
Remaining questions:
1) I don't see why all 16 LEDs per layer are in parallel? Is it because they don't share a common ground connection but each one has an individual ground?
If I imagine the red vertical lines (only drew 2) look like this
and you could also draw it like that
then I think I understand why all 16 LED are in parallel.
2-ish) The calculation for the 100 Ohm resistor results in: 2V is shared among all LEDs and they have to share the 20 mA provided by the current limiting resistor? This would match passerby's calculation of 1.25 mA per LED. I assume 20 mA was chosen to have enough headroom to the max. current?
The I can understand why we don't need transistors.
