so I figured out where the buzzing is coming from in my circuit, and I think I'm starting to see the problem with it.
Here is a schematic I have: Schematic made in altium
The DC/DC step down converter I'm using: http://www.ti.com/lit/ds/symlink/tps54531.pdf
So what this is doing is charging up a super capacitor fairly quickly at 5.6V on the output, and since my feedback is after the current-limiting resistors, I realized now that when the capacitors are fully discharged, I'm essentially shorting the post-resistor node.
So the converter is trying to upkeep a 5.6V after the current-limiting resistors (which at that point is basically ground) which makes it run at full throttle. Not good!
My question is, would moving the feedback before the current-limiting resistors help? What I'm kindof unsure about is since the capacitors are essentially a short to ground at no-charge, would the capacitors initially see no voltage on the input, since it is all dropping across the current-limiting resistors?
Or, would this be compensated by residual charge and the capacitors still charging with some small current and raising the voltage?
Thanks :) If there is some other solution please let me know!!
Well, since it sounds like the supercap and its associated limiting resistors are the load (or at least part of it), then yes, I think your feedback should occur before the resistors, not after them.
