I have a project that uses ngSpice as a shared library. I fed a SPICE file to this project and the same file to ngSpice.exe. The ngSpice.exe finished execution within seconds however, the sharedlibrary goes on and on forever. It just keeps printing "Reference Value"
I have tried using the shared library with the same project before and it worked perfectly. This behavior started out of the blue. Could someone elaborate as to what is going on and why ngSpice.exe does not print this?
That printout should happen only every 0.5 second or so, not at every internal timestep. Maybe you did something to the time/date keeping functions, or provided a wrong ticker value?
-marcel
  • \$\begingroup\$ The only change between the working and the non-working project was that I experimented with ngGet_Vec_info. Apart from this, there hasn't been any other change. I reverted this experimental code but that didn't solve either. If I have inadvertently messed up the time/date keeping functions, why would that be persistent across executions? \$\endgroup\$
    – Aakusti
    Mar 15, 2018 at 18:00
  • \$\begingroup\$ what is a wrong ticker value? \$\endgroup\$
    – Aakusti
    Mar 15, 2018 at 18:01
  • \$\begingroup\$ I have had no luck fixing it. I have gone through the manual and the code a fair number of times now and I can't find a solution. Any help would be a godsend \$\endgroup\$
    – Aakusti
    Mar 15, 2018 at 20:23
There is no "out of the blue".
ngspice shared library does not print anything. All communication is handled via the api.
Probably you intermixed *.o files from ngspice exe with *.o files from ngspice shared library.
Do at least a 'make clean' before you switch from making the exe to making the shared lib.
If that does not help, do a fresh checkout from git.
  • \$\begingroup\$ I have cleaned and rebuilt but no luck. I deleted the entire include folder and reloaded my old one but that doesn't help either \$\endgroup\$
    – Aakusti
    Mar 16, 2018 at 9:13
  • \$\begingroup\$ It got fixed now and I didn't change a thing. I sure did hope to find some issue since if it arose again I could have fixed it but alas. \$\endgroup\$
    – Aakusti
    Mar 16, 2018 at 10:11
