I'm looking for a switch that I can use in my car.
A sensor sends a 12v signal through a wire, into a switch, and out via one of two wires.
For example, if the switch is set to position 1, the 12v will exit through wire 1. Switch position 2, exit via wire 2.
Here's a rough diagram, and my apologies for any incorrect terminology (first time doing anything electrical). Diagram of the layout
    \$\begingroup\$ This is a SPDT switch. \$\endgroup\$ – The Photon Mar 15 '18 at 21:18
  • \$\begingroup\$ Don't answer in the comments. \$\endgroup\$ – Passerby Mar 15 '18 at 22:15
  • \$\begingroup\$ note that most automotive switches are spst with a light section. \$\endgroup\$ – Passerby Mar 15 '18 at 22:18
If you do Google Images "SPDT" you'll get a huge list of circuit diagrams and photographs that might help clarify things. Not really a lot else to say. They're named like this:-
switches
Apart from one thing. Make sure that the current rating of the switch (and wires) is adequate. Don't use a little logic level switch to change between the main battery and the additional battery for the 2T winch. Any concerns, ask here...
| improve this answer | |
  • \$\begingroup\$ Bought a SPDT 12v 24A 3 pin, it's just to intercept a clutch pedal switch and route it to either the main harness ECU port, or a launch control options port. \$\endgroup\$ – fpscolin Mar 15 '18 at 22:40
