I faced some errors while trying to simulate a circuit. I tried to simplify it, but errors still stayed in place :|
The following error message is what I get:
*************** PROCESS COMMAND ***************
/usr/bin/ngspice -n -b /home/rasakereh/Desktop/sharif/9602/EEC/test/test.ckt
*************** PROCESS RESPONSE **************
Warning: singular matrix: check nodes v3#branch and v3#branch
Note: Starting dynamic gmin stepping
Trying gmin = 1.0000E-03 Warning: singular matrix: check nodes v3#branch and v3#branch
Warning: Further gmin increment
Trying gmin = 5.6234E-03 Warning: singular matrix: check nodes v3#branch and v3#branch
Trying gmin = 8.6596E-03 Warning: singular matrix: check nodes v3#branch and v3#branch
Warning: gmin step failed
Warning: source stepping failed
doAnalyses: iteration limit reached
run simulation(s) aborted
Error: no such vector v(4)
Circuit: ********************************************************************************
Doing analysis at TEMP = 27.000000 and TNOM = 27.000000
CPU time since last call: 0.009 seconds.
Total CPU time: 0.010 seconds.
Total DRAM available = 7880.691406 MB.
DRAM currently available = 4678.652344 MB.
Total ngspice program size = 14.774414 MB.
Resident set size = 1.865234 MB.
Shared ngspice pages = 1.638672 MB.
Text (code) pages = 1.333008 MB.
Stack = 0 bytes.
Library pages = 404.000 kB.
I am using gEDA gscheme to generate the schematic, netlisting it using gnetlist and spice-sdb backend, trying to simulate it in gSpiceUi.
Thanks
