Is the ideal output impedance of a Wilson Current Mirror 0?
Also, in the formula for the actual output impedance of Wilson Current Formula (i.e. R_out = [B/2]* r_o), what does r_o stand for? Also, what is the order of magnitude of a Wilson Current Mirror?
| improve this question | | | | |
  • \$\begingroup\$ \$r_o\$ represents the small-signal output resistance defined by the early voltage and the collector current. \$\endgroup\$ – KingDuken Mar 16 '18 at 2:18
  • \$\begingroup\$ Think about it - ideally, it would have infinite output impedance, so no matter what load you attached to, the total impedance (and therefore current) would still be the same. Infinite + Load ≈ Infinite, so your current remains unchanged. \$\endgroup\$ – DSWG Sep 12 '18 at 0:37
The mirror like an ideal current source has infinite impedance except for the leakage r_o due to the Early Effect and Beta, B
https://en.wikibooks.org/wiki/Circuit_Idea/How_the_Wilson_current_mirror_equalizes_the_currents
Order of magnitude for current depends on the device Imax, Pmax and gain matching
| improve this answer | | | | |
    \$\begingroup\$ I recall building a Wilson current mirror out of discretes, with emitter swamping resistors. The Rout was 5 Million ohms, running at 10mA, measured on a Fairchild curve tracer. \$\endgroup\$ – analogsystemsrf Mar 16 '18 at 3:27
