I am not quite sure is VCT(volts center tapped) voltage between one of outer taps and center tap or between two outer taps?
In wikipedia it is said: Volts center tapped (VCT) describes the voltage output of a center tapped transformer. Kinda gives me nothing..
From this thread How to differentiate center-tapped power transformer from a non center-tapped one? one could conclude that it means voltage between outer taps.
For example: will 241-8-24 from https://belfuse.com/resources/241.pdf give me 24V between center tap and outer tap or between both outer taps?
please advise, thanks in advance
  • \$\begingroup\$ Please add a schematic. \$\endgroup\$
    – winny
    Commented Mar 16, 2018 at 9:11
For example: will 241-8-24 give me 24V between center tap and outer tap or between both outer taps?
Answer: between both outer taps is 24 volts.
The device you listed has a secondary voltage of 24 volts and a centre tap so, if you were to use the centre-tap and one of the outer connections to the secondary you would get 12 V RMS out. Another way of describing this output that is sometimes used is "12-0-12". This implies that you get 12V AC either side of the centre tap that is referenced (for convenience) as 0 volts.
