after synthesis in xilinx vivado, I am getting the WARNING:
[Synth 8-5788] Register next_state_reg in module example_code is has both Set and reset with same priority. This may cause simulation mismatches. Consider rewriting code.
why am I getting this warning and how to solve it without changing the logic in the below code sample ?
always @(posedge clk or posedge rst)
begin
    if(rst)
        state <= a;
    else
        state <= next_state;
end
begin
    if(rst)begin
        count = 1;
        wt_refresh = 0;
    end
    else begin
        case(state)
            a: begin
                wt_refresh = 0;
                if(in_put)
                   count = count;
                else if(count < hold*30)
                   count = count+1;
                else begin
                   count = 1;
                   next_state = b;
                   wt_refresh = 1;
                end
               end
            b: begin
                wt_refresh = 0;
                if(in_put)begin
                    count = 1;
                    next_state = a;
                    wt_refresh = 1;
                end
                else begin
                    if(count != 20)
                        count = count+1;
                    else begin
                        count = 1;
                        next_state = c;
                        wt_refresh = 1;
                    end
                end
               end
            c: begin
                wt_refresh = 0;
                if(in_put)
                    count = count;
                else if(count < hold*15)
                    count = count+1;
                else begin
                   count = 1;
                   next_state = d;
                   wt_refresh = 1;
                end
               end
            d: begin
                wt_refresh = 0;
                if(in_put)begin
                    count = 1;
                    next_state = a;
                    wt_refresh = 1;
                end
                else begin
                    if(count != 20)
                        count = count+1;
                    else begin
                        count = 1;
                        next_state = e;
                        wt_refresh = 1;
                    end
                end
               end
            e: begin
                wt_refresh = 0;
                if(in_put)begin
                    count = 1;
                    next_state = a;
                    wt_refresh = 1;
                end
                else
                    next_state = e;
              end
        endcase
    end
  end
  • \$\begingroup\$ It looks like you're trying to do a two always block state machine, but both are sequential. I would recommend converting the second always block to combinatorial and moving the sequential parts to the first always block. \$\endgroup\$ Jul 22, 2018 at 18:59
I have seen that error many times and I find it very annoying and very misleading.
You get it if you have a registers and you do not reset them all.Thus to solve it add "next_state" to your reset part.
The older versions of Xilinx had a better warning message which just said that not all values where reset.
The "next_state" behavior not specified in the "if (rst)" clause will do this. The sad part is that most simulation software will miss it, and some synthesis software (Quartus) will actually create a bogus circuit with unknown behavior...albeit with a warning.
