Design an Isolated battery charger with PFC( power factor correction), which will take input from 230V 3-phase supply. Calculate the value of inductor, transformer and capacitors used. Also, select appropriate switching devices and mention the components used.Required output :117 volt and 40 Amp.
What i have done is i have used the 3 phase rectifier and the caluculation of output rms is V=304.062v and supply current is =69.28A.
Now i am stuck here what should be my net step for smoothening and for PFC.
