So I was thinking about building a deep water camera housing. The housing would be filled with a non-conductive fluid to counter the pressure at depth.
Although fluids like purified water or propylene glycol (anti-freeze mixtures) are stated to be non-conductive, they become ionized when in contact with metals and plastics, thus gradually conducting electricity again. There are ion-exchange resin products that are supposed to keep the fluids de-ionized though. Source: https://www.electronics-cooling.com/2015/12/tech-brief-low-electrical-conductivity-liquid-coolants-for-electronics-cooling/#
So while the electronics might survive being emerged in liquids for a day, what about the 3V lithium batteries that power the camera? Do you expect this thing blowing up in my face in any case, or is there a possiblity that this might work?
    \$\begingroup\$ Some interesting info: Exposure of lithium batteries to external hydrostatic pressure: ffi.no/no/Publikasjoner/Documents/… \$\endgroup\$ – user3002097 Mar 16 '18 at 15:43
    \$\begingroup\$ Transparent mineral oil is also a choice. \$\endgroup\$ – Janka Mar 16 '18 at 15:45
    \$\begingroup\$ @user3002097 where would the oxygen come from for combustion if it's underwater? And propylene glycol is flammable \$\endgroup\$ – Chris H Mar 16 '18 at 15:58
    \$\begingroup\$ Thanks a lot for the clarification, I will take this into account. I'm concerned about the stuff going off on the surface, like in the back of my car when travelling to the lake. \$\endgroup\$ – user3002097 Mar 16 '18 at 16:15
    \$\begingroup\$ @user3002097 What's your rationale for using lithium chemistry? Would you consider batteries with a more docile chemistry? \$\endgroup\$ – Nick Alexeev Mar 16 '18 at 17:25
My recommendation would be;
Lithium Sulfuryl Chloride (Li/SO2CL2)
or Lithium Thionyl Chloride (Li/SOCL2) cells
- only in a Stainless Steel case
- with the unit sealed in Aflas 7182B polymer O-rings.
Criteria; highest energy density with a flat voltage in the strongest high pressure proof case sealed resistant to aggressive chemicals, caustics, high pH, high pressure.
LiPo cells rupture explosions have been well documented under high pressure
  • \$\begingroup\$ ... and no explanation as to why one should go to each of these lengths. \$\endgroup\$ – Nick Alexeev Mar 17 '18 at 0:21
  • \$\begingroup\$ ok ok .......... \$\endgroup\$ – Sunnyskyguy EE75 Mar 17 '18 at 0:27
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
