In the image shown below, there says a syntax error at line 10. Its a basic If statement, i dont know why the syntax error shows up. Please advise Line 9 says syntax error. Will attach image of error also
error message
    \$\begingroup\$ Did you cut and paste the code from a web page? If so, it’s possible your whitespaces are not ASCII tabs/spaces. Try deleting the spaces before the “if” and typing them again. \$\endgroup\$ – Blair Fonville Mar 17 '18 at 9:18
  • \$\begingroup\$ Oh yes i wrote it on notepad and copied onto my geedit via a pen drive. It worked! Thanks \$\endgroup\$ – user181557 Mar 17 '18 at 9:27
The octal \037777777640 values shown in the error appear to be interpretations of no-break spaces (which might come from copy-and-pasting from the web, for example). NBSP has a Hex value of 0xA0, which would equate to the octal values you’re seeing.
Try deleting all of your spaces and retyping them.
    \$\begingroup\$ That must be a common error... \$\endgroup\$ – Solar Mike Mar 17 '18 at 10:47
