I'm trying to compile a simple C file to later upload to my MSP430 uC but when I try to compile I get something that looks like a linking problem:
main.c:7: undefined reference to `outPWM'
my folder contains these files:
  1. main.c
  2. pwm.h
  3. pwm.c
main.c only has this simple instructions:
#include <io.h>
#include <stdint.h>
#include "pwm.h"
int main( void ){
    // Stop watchdog timer to prevent time out reset
    WDTCTL = WDTPW + WDTHOLD;
    outPWM(1,4,100);
    return 0;
pwm.h only has the function prototype and some macros:
#define MCU_CLOCK       160000000
#define PWM_FREQUENCY   50
//Set z% PWM duty cicle output on port x.y
int outPWM(uint8_t x,uint8_t y,uint8_t z);
and pwm.c has the function that is quite big so just for the sake of the example it will be this:
#include <io.h>
#include <signal.h>
#include "pwm.h"
int outPWM(uint8_t port,uint8_t sel,uint8_t PWM_Duty){
    return 0;
I might be using the wrong options while compiling but I have no idea what should I use besides what is provided in some examples on the web that I adapted to this: msp430-gcc main.c -mmcu=msp430x2252 -O2 -Wall -o main.o
What am I doing wrong?
Thank you.
EDIT Corrected function name in pwm.c
    \$\begingroup\$ Which toolchain are you using? \$\endgroup\$ – AndrejaKo Jul 22 '12 at 14:36
  • \$\begingroup\$ @AndrejaKo I'm using msp430-gcc in linux \$\endgroup\$ – Leonardo Marques Jul 22 '12 at 14:40
    \$\begingroup\$ there is no outPWM function mention in pwm.c ? \$\endgroup\$ – pstan Jul 22 '12 at 16:05
  • \$\begingroup\$ @pstan there is, it was my mistake when writing the question I'm sorry \$\endgroup\$ – Leonardo Marques Jul 22 '12 at 19:15
You have to compile both of your source files into your object file. Add pwm.c after main.c on the command line.
